compiling cont.
russ
russ at embedit.com.au
Wed Sep 27 01:23:21 UTC 2000
Hi,
This is a better example of my problem. This is the output when I compile a single file from the
command line:
russ > m68k-rtems-gcc -v -I/opt/rtems/bare-m68302/lib/include heapallocate.c
Reading specs from /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/specs
gcc version 2.95.2 19991024 (release)
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/cpp -lang-c -v -I/opt/rtems/bare-m68302/lib/include
-D__GNUC__=2 -D__GNUC_MINOR__=95 -Dmc68000 -Drtems -D__rtems__ -D__ELF__ -D__mc68000__ -D__rtems__
-D__rtems__ -D__ELF__ -D__mc68000 -D__rtems -Asystem(rtems) -Acpu(mc68000) -Acpu(m68k)
-Amachine(m68k) -Dmc68000 -D__mc68000 -D__mc68000__ heapallocate.c /tmp/cciqFySH.i
GNU CPP version 2.95.2 19991024 (release) (68k, Motorola syntax)
#include "..." search starts here:
#include <...> search starts here:
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/include
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/include
End of search list.
The following default directories have been omitted from the search path:
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../include/g++-3
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/sys-include
End of omitted list.
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/cc1 /tmp/cciqFySH.i -quiet -dumpbase heapallocate.c
-version -o /tmp/ccQjQxOm.s
GNU C version 2.95.2 19991024 (release) (m68k-rtems) compiled by GNU C version 2.7.2.3.
/opt/rtems/m68k-rtems/bin/as -mc68000 -o /tmp/ccgd17n4.o /tmp/ccQjQxOm.s
/tmp/ccQjQxOm.s: Assembler messages:
/tmp/ccQjQxOm.s:22: Error: invalid instruction for this architecture; needs 68020 or 68030 or 68040
or 68060 or cpu32 -- statement `divul.l 20(%a0),%d1:%d0' ignored
The m68k I use is for the 68000, not the 68020, but the assembler wants 68020. Is this built into
the rpm's? Do I have to rebuild everything from source and not use the rpm's. Or is there something
I'm missing?
Thanks
russ
