OR32 Newlib Committed to Opencores.org
Rosimildo da Silva rdasilva at connecttel.com
Wed Sep 6 00:46:58 UTC 2000
Joel Sherrill wrote:
> I just committed the current RTEMS patch which includes
> or32 configuration support to the newlib repository
> at opencores.org.  This means that anyone should be able
> to check out binutils, gcc, and newlib and build
> an or32-rtems toolset.
> NOTE: I just built C.  The last time I tried C++, the
> compiler died.
> I can post detailed configure/build instructions but this
> much should get folks started:
> checkout binutils, gcc, and newlib from opencores.org
I have set:
set CVSROOT=:pserver:cvs at cvs.opencores.org:/home/oc/cvs
when I try to login, password= 'cvs' I get an error:
D:\unix\source\or32>cvs login
(Logging in to cvs at cvs.opencores.org)
CVS password:
cvs [login aborted]: authorization failed: server cvs.opencores.org
rejected access
Rosimildo da Silva            rdasilva at connectel.com
ConnectTel, Inc.              Austin, TX -- USA
Phone : 512-338-1111          Fax : 512-918-0449
Mobile: 512-632-7579
Company Page: http://www.connecttel.com
Home Page: http://members.xoom.com/rosimildo/
