Accessing hardware under RTEMS
Gerwin Pfab
pb at schenk.isar.de
Thu Sep 14 07:45:04 UTC 2000
On Wed, 13 Sep 2000, OUTWATER wrote:
> Greetings all -
> I have an application in which I need to provide contol of miscellaneous
> peripheral devices such as:
> LEDs
> Memories (SRAM, FIFO)
> Hardware control registers
> It seems like the best/elegant/preferred way to do this is via RTEMS device
> drivers.
> Opinions?
I think that depends on your needs. Controlling some LEDS can be done by a
set of simple functions or even by some macros, so why bother about a
device driver?
If your SRAM, FIFO and hardware control registers have application
dependant meanings, writing a library that abstracts the functionality
from the implementation may be the best solution.
If your Hardware implements something that should have a interface like a
character or block device, then a device driver is needed.
> If a device driver is the way to go, is there a basic example of one somewhere
> that I could use as a starting point?
> Thanks!
> Keith
Regards
Gerwin
Gerwin Pfab <pb at schenk.isar.de> Dr. Schenk Industriemesstechnik GmbH
Dipl. Ing. Einsteinstrasse 37
Software Engineering D-82152 Martinsried
Tel: +49-89-85695-0
Fax: +49-89-85695-200
