Using RTEMS with Ada
Simon Clubley
simon_clubley at excite.com
Sun Apr 8 17:40:35 UTC 2001
What versions of the tools/RTEMS are the Ada users actually using ?
Did you have to make any alterations to these versions ?
My host platform is x86 Linux (Redhat 6.2) and my target platform is
the pc386 BSP. I am aware, from reading the archives, of the issues
regarding Ada and the current versions of the tools/RTEMS. However,
as this is for personal interest only, a combination of the older
tools/RTEMS would be fine.
I see as well that the started_ada.ps instructions for 4.0.0
reference gnat-3.10p/gcc-2.8.1, but that the gcc patch in this
version of GNAT is for GCC-2.7.2. Is there a version of the gcc-2.8.1
patch for gnat-3.10p that I have not found yet ?
I also see that the pre-compiled binaries for this version of GNAT
do not appear to run on Redhat 6.2 (It fails in the linker when I
do a hello_world.c test because it cannot find one of the crt*
modules) so are you also using an older Linux/libraries as well ?
Thanks for any replies
Simon.
Simon Clubley
_______________________________________________________
Send a cool gift with your E-Card
http://www.bluemountain.com/giftcenter/
