PPP Question
Mike Siers
mikes at poliac.com
Thu Apr 26 20:38:09 UTC 2001
Hi,
I am trying to use the pppd code of the latest RTEMS
snapshot (2001/04/24). I have an OpenBSD server that
is set up to receive incoming PPP connections over
a null modem serial cable without any authentication.
I can successfully connect to the server using Windows.
I am now trying connect from my RTEMS test PC. I am using
the i386/pc586 BSP. I am using the standard tty driver
and I register the ppp_tty callback functions for the PPP
line discipline. I also modified the pppdmain code so it
does not worry about processing a connection string.
When I execute this software, it reports the following
strings to the console:
ppp0 bad protocol 0xffff88a0
syslog: read: m
syslog: read: m
If I run ifconfig on the server box, I get the following
information:
tun0: flags=11<UP,POINTOPOINT> mtu 1500
But I do not see the tun0 interface entered anywhere into
the routing table on the server. The server ppp log file
reports the following:
LCP: deflink: LayerFinish
LCP: deflink: State change Starting-->Initial
Has anyone done something similar? Any information would
be greatly appreciated.
Thanks
Mike Siers
