Problems with rtems-ss-20010326
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Apr 6 10:32:32 UTC 2001
Andy Dachs wrote:
> I tried applying the 20010126-20010326 patch yesterday
> and ran into problems.  It seems that the BSP directory
> is installed one level lower than it used to be, e.g.:
Yes, several installation and preinstallation directories have
moved.
> in previous versions:
> ./rtems/powerpc-rtems/psim
> now:
> ./rtems/powerpc-rtems/powerpc-rtems/psim
Depending on the installation PREFIX (the value passed with
--prefix=PREFIX) this could be OK.
What's your installation prefix?
> Although rtems builds ok it causes multiple
> problems with application makefiles.
Which application Makefiles are you refering to (there are several
of them) and which detail goes wrong?
> Is this correct behaviour or has the BSP
> somehow landed up in the wrong location?
cf. above
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
