i386 bsp issues
lange92 at 2067.resnet.uni.edu
Wed Aug 1 21:13:46 UTC 2001
Hi all,
I attempted to compile the i386-rtems bsp manually, using the configure
script, using the command:
../rtems-4.5.0/configure --target=i386-rtems --enable-posix
--enable-rtemsbsp="pc386"
--prefix=/users/lange92/illinoiscentral/build-i386-coff-rtems
I modified the pc386/lib/bsp_specs, removing the entries for crti.o and
crtn.o (it looks suspiciously like the bsp_specs from rtems-4.0.0). It
compiles further now, but then it bombs out with the following errors:
../../../../../../pc386/lib/librtemsall.a(bootcard.o): In function `boot_card':
bootcard.c:108: undefined reference to `bsp_start'
bootcard.c:122: undefined reference to `_fini'
bootcard.c:123: undefined reference to `_init'
A monster grep shows bspstart.c has at least the first routine, but I
could not locate a bspstart.h file to #include in the rest of the system.
I do not see how the functions defined in bspstart.c could be used
otherwise, unless it's built to a .o and linked against directly.
Any ideas where to go from here?
Thanks in advance,
DanL
