do ... while(0) in macros
Wed Aug 8 12:36:39 UTC 2001
This explanation is dead on the money.  If you define
more than a single statement in a macro, it is a
good habit to get into.  It is a good way to avoid
bizarre and hard to debug problems like the one
Paul is describing.
One of the first RTEMS users taught me this
trick (thanks Tony :).
--joel
Paul Whitfield wrote:
> Hi
> The do{} while inside a macro is a common idiom
> to ensure that the macros always behave correctly
> when used in various different ways particularly
> with if statements
> for example:
> #define Macro() \
>         call_one(); \
>         call_two();
> if (test)
>    Macro();
> The the above macro would call function call_one
> if test was true, but would always call call_two.
> while if we define the macro as
> #define Macro do { \
>         call_one(); \
>         call_two(); \
>         } while(0);
> Both call_one and call_two will be called only if test is true.
> Hope that makes sense.
> Regards
> Paul
> CARERI/SED wrote:
> > There are many macros in RTEMS written like the following code:
> >   do { \
> >     unsigned32 _stack; \
> >     if ( (_isr) ) (_the_context)->eflags = CPU_EFLAGS_INTERRUPTS_OFF;
> >     else          (_the_context)->eflags = CPU_EFLAGS_INTERRUPTS_ON; \
> >     _stack = ((unsigned32)(_stack_base)) + (_size) - 4; \
> >     *((proc_ptr *)(_stack)) = (_entry_point); \
> >     (_the_context)->ebp     = (void *) _stack; \
> >     (_the_context)->esp     = (void *) _stack; \
> >   } while (0)
> > Could anybody explain the purpose of the "do ... while(0)" ?
> > Thanks in advance,
> > Guo
> Paul Whitfield
> Senior Software Engineer
> Microsol (Aust) Ltd
> Phone: (+61) 08 9473 6646
> Fax:   (+61) 08 9473 6699
