ACATS results for GNAT/RTEMS 3.13p on PowerPC
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Aug 16 19:20:52 UTC 2001
Hi,
I will be uploading RPMs in a while but wanted to post
the results of running the ACATS on powerpc-rtems/psim
for general perusal.
These were done with the acats4gnats-0.2 scripts in the
contrib directory. Thanks Laurent. :)
acats4gnat results cz 3 / 4
acats4gnat results a 75 / 75
acats4gnat results c2 35 / 35
acats4gnat results c3 347 / 349
acats4gnat results c4 333 / 338
acats4gnat results c5 95 / 95
acats4gnat results c6 81 / 81
acats4gnat results c7 47 / 50
acats4gnat results c8 140 / 140
acats4gnat results c9 246 / 255
acats4gnat results ca 73 / 74
acats4gnat results cb 43 / 43
acats4gnat results cc 117 / 117
acats4gnat results cd 172 / 172
acats4gnat results ce 262 / 268
acats4gnat results cxa 85 / 85
acats4gnat results cxb 29 / 30
acats4gnat results cxc 9 / 16
acats4gnat results cxd 27 / 39
acats4gnat results cxe 1 / 1
acats4gnat results cxf 20 / 20
acats4gnat results cxg 28 / 29
acats4gnat results cxh 4 / 4
acats4gnat results d 4 / 4
acats4gnat results e 11 / 11
acats4gnat results l 26 / 26
Although there are failures, this compares quite favorably
with the results on Linux where some of the same tests
also fail.
joel at OARcorp.com On-Line Applications Research
