GO32 BSP
Joel Sherrill joel at OARcorp.com
Fri Aug 17 21:37:49 UTC 2001
Camilo Alejandro Arboleda wrote:
> Hello
> Has anybody worked with GO-32bsp?
This BSP was declared obsolete between 4.0 and 4.5.  If you want to use
a PC as a target, then try the pc386 BSP on the i386-rtems target.  It
produces
various format executables that can be used with a number of boot loaders.
It supports variants for different CPU models (486, p5, k6, etc.)
> I was able to make the compiler and the binutils, but not the system
> itself (I first tried with rtems 4.0).
> I was trying to do it with djgpp 2.
As I recall, it only worked with djgpp 1 which was part of the reason
for abandoning it.  Everyone
seemed more interested in the native RTEMS version.
> Thanks,
