FW: Anybody using Windows 98 for RTEMS GNU tools?
Sreedharan Bhaskaran sreedhar at singnet.com.sg
Wed Aug 29 16:04:17 UTC 2001
Hi,
I am using win98 to cross-compile rtems-4.5.0 for a sparcv8 system
under cygwin. I have not encountered any problems with cygwin nor
the cross compiler. normal gcc for local compiles (vs. cross compile)
works just as fine.
I dual boot with Linux RH6.2 and compilation under Linux is much
faster than cygwin.
I haven't tried recompiling binutils, not much help there.
cheers,
Sree
> -----Original Message-----
> From: Maarten.Kruger at ziton.spx.com [mailto:Maarten.Kruger at ziton.spx.com]
> Sent: Wednesday, August 29, 2001 3:50 PM
> To:
> Subject: Anybody using Windows 98 for RTEMS GNU tools?
> Good day,
> The getting started .pdf manual states that Windows 95 is not suitable for
> compiling and debugging RTEMS in Cygwin...  Since the document is
> quite old
> - I was wondering if this is still true?  I am using Windows '98 and would
> like to use it just to get started with RTEMS until I install Mandrake 7.2
> (think this is a good choice?) ...  I would still like to use Windows '98
> for other work (can't dual boot all the time)...
> Is anybody successfull using all the GNU tools in Windows 98 for RTEMS?
> Can you please give me tips for getting started - had problems with
> Cygwin...
> thanks
> Maarten Kruger
