network trouble on 68360 (ACE360/HSB)
Joe Novosel
jnovosel at broadcom.com
Wed Aug 29 21:48:24 UTC 2001
Hello,
I have recently started working with RTEMS (personal use).
I am using an ACE360/HSB board.
Here's my trouble:
I'm attempting to use the 4.5.0 release. (Redhat 7.1 and pd bdm interface
with gdb 5.0)
I can get everything working fine except I can't TRANSMIT ethernet packets.
I can recieve just fine since MAC addresses are being learned (see below)
I get "carrier sense lost" and the packet is thrown away.
I have compiled RTEMS with and without support for the Atlas HSB.
I have tried this on several boards with different memory configurations and
power supplies (both a stand-alone and lab supply) Also I've tried several
different network cables and direct connect to the pc with a xover cable.
I'm getting link indication.
I've looked at the instructions that I have for the board and everything
SEEMS to be set up correctly.
This is the output from "netdemo"
Destination Gateway/Mask/Hw Flags Refs Use Expire Interface
default 192.168.1.1 UGS 0 0 0 scc1
192.168.1.0 255.255.255.0 U 0 0 1 scc1
192.168.1.1 UHL 1 0 1 scc1
192.168.1.53 00:A0:CC:D1:F5:82 UHL 0 0 1309 scc1
************ MBUF STATISTICS ************
mbufs: 512 clusters: 64 free: 48
drops: 0 waits: 0 drains: 0
free:494 data:18 header:0 socket:0
pcb:0 rtable:0 htable:0 atable:0
soname:0 soopts:0 ftable:0 rights:0
ifaddr:0 control:0 oobdata:0
************ INTERFACE STATISTICS ************
***** scc1 *****
Address:192.168.1.100 Broadcast Address:192.168.1.255
Flags: Up Broadcast Running Simplex
Send queue limit:50 length:0 Dropped:0
Rx Interrupts:99 Not First:0 Not Last:0
Giant:0 Runt:0 Non-octet:0
Bad CRC:0 Overrun:0 Collision:0
Discarded:0
Tx Interrupts:0 Deferred:0 Missed Hearbeat:0
No Carrier:96 Retransmit Limit:0 Late Collision:0
Underrun:0 Raw output wait:0 Coalesced:0
Coalesce failed:0 Retries:0
************ IP Statistics ************
total packets received 3
datagrams delivered to upper level 3
************ ICMP Statistics ************
************ UDP Statistics ************
total input packets 3
of above, arrived as broadcast 3
************ TCP Statistics ************
Any help or suggestions would be greatly appreciated!
Thanks,
Joe
Joe Novosel
Test Engineer
Broadcom Corporation
Residential Broadband Unit
678-475-3216 direct
770-232-0018 operator
