gdb and bdm for RTEMS
Larry Gray larry at greenmotor.com
Fri Aug 31 14:10:45 UTC 2001
Hello,
	I'm somewhat confused about which bdm version to use with RTEMS. First I'm
using an efi332 board, with the public domain bdm board (5 chip version).
m68k-rtems-gdb-4.18-4.i386.rpm doesn't have bdm support, so I downloaded
gdb-4.18.tar.gz, gdb-4.18-rtems-20000524.diff.gz, and
gdb-bdm-20010415.tar.gz.
	However, it appears that gdb-bdm-20010415.tar.gz is only for CPU32+ (68360
and Coldfire), is this correct?
	I also tried gdb-4.18-bdm-patches-pi1.tar.gz, I compiled the driver, and
patched and compiled gdb. The driver loads, gdb starts, but when I try
"target bdm /dev/pd_bdm0" , gdb returns:
Error: BDM device driver version conflict.
        you need at least version 2, currently installed is version 1.
        Aborting operation
	What bdm driver do I need for the 68332? Also, how do I create a gdb version
with both bdm and RTEM's support?
	I apologize for the somewhat off topic questions, but maybe somebody can
point me in the right direction.
Thanks,
Larry Gray
