The best way to rewrite rtems task code.
Wed Aug 8 21:02:02 UTC 2001
Fernando RUIZ CASAS wrote:
> I have several programs in RTEMS that runs new tasks dinamically.
> I want rewrite this code for linux ETRAX100 lx EVB .
> I don't want rewrite from the scratch.
> How I can simulate in linux the rtems task_create and more?
> Posix pthreads perhaphs? Can you say me a good book about this?
A lot depends on what else of the Classic API you are using.
If you are using features that map cleanly onto POSIX, then
I would be prone to rewrite in POSIX.  If not, then you have
some redesign work.  What parts of the Classic API are you
really using?
> Better rebuilding from the scratch and writing a clasic unix server program?
Definitely not.  The worst case is using the POSIX threads interface
and running the same code in both places.  This just might require
some rewrite.
> Fernando RUIZ CASAS
> home: correo at fernando-ruiz.com
> work: fernando.ruiz at ctv.es
>    winmail.dat    Type: application/ms-tnef
>               Encoding: base64
