psim BSP problem
Fri Aug 10 12:51:17 UTC 2001
Kiran C wrote:
> Hi,
>     I have success fully build and run a project in the pc386 BSp and UNIX
> BSP.
> Later when I build the same project for the psim BSP.The program ran in the
> psim but did not
> return SUCCESS.(that  is the ..it did not produce the same same out put as
> in pc386 BSP and UNIX BSP)
> What could be possibly wrong?
> The only system call that is used by my code is malloc.
Some of the simulators do not return the exit code all the way through
the
simulator back out to UNIX.  if the output was OK and the program
exitted
at all, then it passed.
> Thanks,
> Kiran
