GO32 BSP
Camilo Alejandro Arboleda
Carboleda at angelcomsa.com
Fri Aug 17 22:01:49 UTC 2001
> This BSP was declared obsolete between 4.0 and 4.5. If you want to use
> a PC as a target, then try the pc386 BSP on the i386-rtems target. It
> produces
> various format executables that can be used with a number of boot loaders.
> It supports variants for different CPU models (486, p5, k6, etc.)
It's a problem because my target board comes with an M-Systems Diskonchip,
and is not possible to boot rtems from this device. It only boots DOS.
If you know some way to boot RTEMS from Diskonchip Millennium, it would be a
big help.
