Hi,
RTEMS ss-20011203 is now available from:
ftp:://ftp.oarcorp.com/pub/rtems/snapshots/current
It includes a lot of "under the hood" work but as of last night,
all of the BSPs that are expected to compile, did so.
Some build highlights:
+ This snapshot is a big step toward moving all BSP specific
defines from custom/*.cfg down in the tree to the libbsp
code that actually uses them. That required a fair amount
of Makefile magic from Ralf and is a prerequisite for
having a multilib RTEMS and separate BSP Kit.
+ BSPs now should use their own configure.ac script for compile
time options over custom/*.cfg.
+ ods68302 bsp hacked to get symbols at link time not build time.
+ PowerPC new versus old exception processing is now a per
BSP option to simplify per CPU builds.
Some non-build highlights:
+ Obsoleted Two BSPs
+ Score603e generation 1 board obsoleted
+ Papyrus BSP obsoleted
+ PPC405 support including NEW!! gen405 BSP
+ MCF5206eLITE BSP (NEW!!) includes i2c support
+ mpc8260 has double not single FPU
+ mptest tested per PR36
+ Cleaner handling of PowerPC case of varying implementation
of the routine _ISR_Is_in_progress() per PR91.
+ If C++ constructions are run in __main(), then they
are now invoked when first task runs like __init(). PR84.
+ chdir() now checks permissions per PR63.
+ ERC32 TM27 macros rewritten per PR80.
+ imfs_load_tar.c has minor change to avoid tripping gcc bug on m5200
+ m68k rdbg support now compiles on ColdFire
+ rtems++ test now links when DEBUG variant per PR78
+ Per PR72 many mptests now run
+ Properly account for stack memory in sp26 per PR78.
joel at OARcorp.com On-Line Applications Research
