RTEMS ss-20011203 Available
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Thu Dec 6 02:54:56 UTC 2001
Am Die, 2001-12-04 um 01.41 schrieb Joel Sherrill:
> Hi,
> RTEMS ss-20011203 is now available from:
> ftp:://ftp.oarcorp.com/pub/rtems/snapshots/current
> It includes a lot of "under the hood" work but as of last night,
> all of the BSPs that are expected to compile, did so.
> Some build highlights:
> + This snapshot is a big step toward moving all BSP specific
> defines from custom/*.cfg down in the tree to the libbsp
> code that actually uses them. That required a fair amount
> of Makefile magic from Ralf and is a prerequisite for
> having a multilib RTEMS and separate BSP Kit.
Unfortunately, an oversight related to this activity has made it into
the snapshot and can cause problems with the bootstrap-script.
Therefore, if you should encounter problems related to bspopts.h,
autoheader or bootstrap, you might probably want to apply the patch
below.
To apply the patch.
cd rtems
patch -p0 < rtems-rc-20011204-2a.diff
./bootstrap
[Requires to have autoconf-2.52 and automake-1.5 installed]
Ralf
Index: bootstrap
RCS file: /usr1/CVS/rtems/bootstrap,v
retrieving revision 1.5
diff -u -r1.5 bootstrap
--- bootstrap 2001/09/21 15:01:28 1.5
+++ bootstrap 2001/12/04 10:59:46
@@ -82,6 +82,8 @@
aclocal $aclocal_args;
test -n "`grep CONFIG_HEADER ${configure}`" && autoheader \
&& test "$verbose" = "-v" && echo "autoheader";
+ test -n "`grep RTEMS_BSP_CONFIGURE ${configure}`" && autoheader \
+ && test "$verbose" = "-v" && echo "autoheader";
test -f Makefile.am && automake -a -c $verbose ;
autoconf;
test -f Makefile.am && test -n "`grep 'stamp-h\.in' Makefile.in`" \
@@ -115,6 +117,7 @@
fi; done
find . -name '*~' -print | xargs rm -f
+ find . -name 'bspopts.h*' -print | xargs rm -f
find . -name '*.orig' -print | xargs rm -f
find . -name '*.rej' -print | xargs rm -f
find . -name 'config.status' -print | xargs rm -f
