RTEMS gdb
Thomas Smeraldi thomas at utstar.com
Fri Dec 7 13:58:13 UTC 2001
Hi Eric,
Thanks for the information. I had read this section of
the RTEMS doc library prior to sending the request. I thought
there was another document that may be available which contained
more details about the changes to the GDB code.
While I have your attention, could you give me a brief description
as to how the 'target_ops' functions get executed in GDB? Prior to
this thread I cited a problem I'm having using the GDB under Cygwin
communicating with a target MPC8260 CPU. Other than attach and detach,
no other remote functions are called, e.g., 'remote_insert_breakpoint',
and the other functions contained in gdb/remote-rte.c when issuing
the standard GDB debug commands. If you can point me in the right
direction, I would really appreciate it.
Thanks.
Tom Smeraldi
UTStarcom, Inc.
-----Original Message-----
From: VALETTE Eric [mailto:valette at crf.canon.fr]
Sent: Friday, December 07, 2001 7:57 AM
To: Thomas Smeraldi
Cc: rtems-users
Subject: Re: RTEMS gdb
Thomas Smeraldi wrote:
> Hi Eric
> Could you or someone tell me how to obtain a copy of the document
> mentioned below, "RTEMS Remote Debugger Server Specifications"?
Its right there in several format...
<http://www.oarcorp.com/rtems/releases/4.5.0/rtemsdoc-4.5.0/share/rtemsdoc/h
tml/index.html>
    __
   /  `                          Eric Valette - Canon CRF
  /--   __  o _.                 Product Dev. Group Software Team Leader
(___, / (_(_(__                 Rue de la touche lambert
                                 35517 Cesson-Sevigne  Cedex
                                 FRANCE
Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
