A newbie Question
Steelen
rtems at btamail.net.cn
Thu Dec 20 02:16:48 UTC 2001
I need your help!
I think perhaps something is wrong with the install directories of my RTEMS.
Here is the directory structure,can you tell me is there anything wrong?
this is the direcory structure of RTEMS compiler files
/opt/rtems/bin the compiler files
/opt/rtems/i386-rtems
/opt/rtems/include
/opt/rtems/info
/opt/rtems/lib
/opt/rtems/man
/opt/rtems/share
this is director of RTEMS soure code.
/opt/rtems/rtems-4.5.0 .......
/opt/rtems/hello_world_c-4.5.0 hell world source file directory
/opt/rtems/build the target file generate by ../rtems-4.5.0.configure
Here is the command I use to configure
#! /bin/sh
export PATH=$PATH:/opt/rtems/bin
../rtems-4.5.0/configure --target=i386 \
--program-prefix=i386-rtems-
Is there anything wrong??
This problem has suffered me for about a month. I'm very eager to know how to sovle it.
Thanks a lot .
I'm using Redhat 7.2,PIII,256M SDRAM
I download the RPMS for x86 and install them.,it seems work well.
I download the source code of 4.5.0 ,uncompress to a directory in
/opt/rtems-4.5.0, I make a directory /opt/target
I run ../rtems-4.5.0/configure --program-prifix=/rtems-i386- \
--prefix=/opt/rtems
URL: <http://lists.rtems.org/pipermail/users/attachments/20011220/8504da77/attachment.html>
