task monitor
Correo Fernando-ruiz (E-mail)
correo at fernando-ruiz.com
Mon Dec 3 19:44:37 UTC 2001
dump_cpu_usage() perhaphs?
This is a pretty tool to see the task activity.
You have it into rtems_monitor() command list.
A task monitor ready to use without more things.
You can add a wonderful kill task(), resume task, and more commnads
easyly in order to give a total task control.
My shell implementation have all the monitor commands and more.
It's very extensible adding new commands in your source and
registering them.
Adding a task extension in your user module and adding the command shell
routines you can get a powerful control task.
See you.
BRGDS.
Fernando RUIZ CASAS
home: correo at fernando-ruiz.com
work: fernando.ruiz at ctv.es
> -----Mensaje original-----
> De: Peter Mueller [mailto:peter.o.mueller at gmx.de]
> Enviado el: domingo, 02 de diciembre de 2001 19:00
> Para: rtems list
> Asunto: task monitor
> Hi all,
> I like to monitor execution of an rtems application. I saw
> that the necessary OS hooks are already there to get e.g.
> task switching et cetera. My plan is to log such system
> events in a large ring buffer. The buffer could be displayed later on.
> Before starting to work I like to know if something like that
> is already there?
> Is there a monitoring tool around that has an open interface
> that I can use for presentation ( a la windview)?
> Peter
> Peter Mueller
