Help Building RTEMS for Windows NT
Gerke Kok
gerke.kok at tpa-nl.com
Tue Dec 4 09:59:49 UTC 2001
Hi,
looks like you are missing some tools here. Did you use the Cygwin-Install of the OAR site? Then you could have use the rpm-files. These do a lot of good for you. (I know: it's a big download... :-( )
You are at least missing autoconf, automake etc. These maight be quite important in the building process... Goodluck!
wkr,
Gerke
*********** REPLY SEPARATOR ***********
On 04/12/01 at 15:43 Paul Whitfield wrote:
>Hello All,
>I am having some problems building RTEMS on Windows NT.
>I have the same problem for release 4.5.0 and the pre-release
>4.5.1-pre3. The following is all for 4.5.0
>If have downloaded and installed the relavent tar.gz files
>(not the RPMs)
>I have followed the instructions in the Getting Started guide, and
>seem to get started configure started OK.
>The configuration process seems to work OK (see log attached below)
>but when it gets the point where checks to see if the rtems compiler
>works it "locks up".
>This is very odd, because the cmd.exe window scroll bar then "goes
>away". (Like the executeable is a 16 bit app).
>The cmd window now will not respond and I can not control-c inside this
>window (well I can but it does nothing).
>I have everying all the RTEM stuff installed in /opt
>I have the / filesystem mounted in binary mode
>I am using an up-to-date version of Cygwin.
>I am running Windows NT4 Service Pack 6
>The m68k-rtems-gcc works correctly if I compile a small fragment
>of code.
>The output of m68k-rtems-gcc -v is
>$ m68k-rtems-gcc -v
>Reading specs from /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/specs
>gcc version 2.95.2 19991024 (release)
>Any help greatly appreciated
>Best regards
>Paul Whitfield
>$ ../../rtems-4.5.0/configure --target=m68k-rtems
>loading cache ./config.cache
>checking for RTEMS Version... 4.5.0
>checking host system type... i386-pc-cygwin32
>checking target system type... m68k-unknown-rtems
>checking build system type... i386-pc-cygwin32
>checking rtems target cpu... m68k
>checking for a BSD compatible install... (cached) /usr/bin/install -c
>checking whether build environment is sane... yes
>checking whether make sets ${MAKE}... (cached) yes
>checking for working aclocal... missing
>checking for working autoconf... missing
>checking for working automake... missing
>checking for working autoheader... missing
>checking for working makeinfo... found
>checking whether to enable maintainer-specific portions of Makefiles... no
>checking if the test suites are enabled? ... no
>checking if cpu m68k is supported... yes
>updating cache ./config.cache
>creating ./config.status
>creating Makefile
>creating tools/Makefile
>creating make/Makefile
>creating make/custom/Makefile
>creating make/Templates/Makefile
>creating make/compilers/Makefile
>creating doc/Makefile
>configuring in tools/build
>running /bin/sh ../../../../rtems-4.5.0/tools/build/configure
>--target=m68k-rtems --cache-file=../.././config.cache
>--srcdir=../../../../rtems-4.5.0/tools/build
>loading cache ../.././config.cache
>checking for Cygwin environment... (cached) yes
>checking for mingw32 environment... (cached) no
>checking for executable suffix... (cached) .exe
>checking for gcc... (cached) gcc
>checking whether the C compiler (gcc ) works... yes
>checking whether the C compiler (gcc ) is a cross-compiler... no
>checking whether we are using GNU C... (cached) yes
>checking whether gcc accepts -g... (cached) yes
>checking for strerror... (cached) yes
>checking for strtol... (cached) yes
>checking for bash... (cached) /usr/bin/bash
>updating cache ../.././config.cache
>creating Makefile
>creating install-if-change
>creating lock-directory
>creating unlock-directory
>creating config.h
>config.h is unchanged
>configuring in tools/update
>running /bin/sh ../../../../rtems-4.5.0/tools/update/configure
>--srcdir=../../../../rtems-4.5.0/tools/update
>checking for perl... no
>creating Makefile
>configuring in tools/cpu
>running /bin/sh ../../../../rtems-4.5.0/tools/cpu/configure
>--srcdir=../../../../rtems-4.5.0/tools/cpu
>creating Makefile
>configuring in generic
>running /bin/sh ../../../../../rtems-4.5.0/tools/cpu/generic/configure
>--target=m68k-rtems --cache-file=../../.././config.cache
>--srcdir=../../../../../rtems-4.5.0/tools/cpu/generic
>loading cache ../../.././config.cache
>updating cache ../../.././config.cache
>creating Makefile
>creating size_rtems
>configuring in m68k-rtems/c
>running /bin/sh ../../../../rtems-4.5.0/c/configure --target=m68k-rtems
>--cache-file=./config.cache --srcdir=../../../../rtems-4.5.0/c
>creating cache ./config.cache
>checking for a BSD compatible install... /usr/bin/install -c
>checking whether make sets ${MAKE}... yes
>checking for bsps... dmv152 efi332 efi68k gen68302 gen68340 gen68360
>gen68360_040 idp mvme136 mvme147 mvme147s mvme162 mvme162lx mvme167
>ods68302 .. done
>checking for make/custom/dmv152.cfg... yes
>checking for make/custom/efi332.cfg... yes
>checking for make/custom/efi68k.cfg... yes
>checking for make/custom/gen68302.cfg... yes
>checking for make/custom/gen68340.cfg... yes
>checking for make/custom/gen68360.cfg... yes
>checking for make/custom/gen68360_040.cfg... yes
>checking for make/custom/idp.cfg... yes
>checking for make/custom/mvme136.cfg... yes
>checking for make/custom/mvme147.cfg... yes
>checking for make/custom/mvme147s.cfg... yes
>checking for make/custom/mvme162.cfg... yes
>checking for make/custom/mvme162lx.cfg... yes
>checking for make/custom/mvme167.cfg... yes
>checking for make/custom/ods68302.cfg... yes
>creating Makefile
>configuring in make
>running /bin/sh ../../../../../rtems-4.5.0/c/make/configure
>--target=m68k-rtems --with-target-subdir=m68k-rtems
>--cache-file=.././config.cache --srcdir=../../../../../rtems-4.5.0/c/make
>loading cache .././config.cache
>checking for m68k-rtems-gcc... /opt/rtems/bin/m68k-rtems-gcc
>checking whether the C compiler (/opt/rtems/bin/m68k-rtems-gcc ) works...
>Paul Whitfield
>Senior Software Engineer
>Microsol (Aust) Pty Ltd
>Phone: (+61) 08 9473 6646
>Fax: (+61) 08 9473 6699
