Help Building RTEMS for Windows NT
Paul Whitfield paulw at microsol.iinet.net.au
Tue Dec 4 07:43:22 UTC 2001
Hello All,
I am having some problems building RTEMS on Windows NT.
I have the same problem for release 4.5.0 and the pre-release
4.5.1-pre3. The following is all for 4.5.0
If have downloaded and installed the relavent tar.gz files
(not the RPMs)
I have followed the instructions in the Getting Started guide, and
seem to get started configure started OK.
The configuration process seems to work OK (see log attached below)
but when it gets the point where checks to see if the rtems compiler
works it "locks up".
This is very odd, because the cmd.exe window scroll bar then "goes
away". (Like the executeable is a 16 bit app).
The cmd window now will not respond and I can not control-c inside this
window (well I can but it does nothing).
I have everying all the RTEM stuff installed in /opt
I have the / filesystem mounted in binary mode
I am using an up-to-date version of Cygwin.
I am running Windows NT4 Service Pack 6
The m68k-rtems-gcc works correctly if I compile a small fragment
of code.
The output of m68k-rtems-gcc -v is
$ m68k-rtems-gcc -v
Reading specs from /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/specs
gcc version 2.95.2 19991024 (release)
Any help greatly appreciated
Best regards
Paul Whitfield
$ ../../rtems-4.5.0/configure --target=m68k-rtems
loading cache ./config.cache
checking for RTEMS Version... 4.5.0
checking host system type... i386-pc-cygwin32
checking target system type... m68k-unknown-rtems
checking build system type... i386-pc-cygwin32
checking rtems target cpu... m68k
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal... missing
checking for working autoconf... missing
checking for working automake... missing
checking for working autoheader... missing
checking for working makeinfo... found
checking whether to enable maintainer-specific portions of Makefiles... no
checking if the test suites are enabled? ... no
checking if cpu m68k is supported... yes
updating cache ./config.cache
creating ./config.status
creating Makefile
creating tools/Makefile
creating make/Makefile
creating make/custom/Makefile
creating make/Templates/Makefile
creating make/compilers/Makefile
creating doc/Makefile
configuring in tools/build
running /bin/sh ../../../../rtems-4.5.0/tools/build/configure
--target=m68k-rtems --cache-file=../.././config.cache
--srcdir=../../../../rtems-4.5.0/tools/build
loading cache ../.././config.cache
checking for Cygwin environment... (cached) yes
checking for mingw32 environment... (cached) no
checking for executable suffix... (cached) .exe
checking for gcc... (cached) gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for strerror... (cached) yes
checking for strtol... (cached) yes
checking for bash... (cached) /usr/bin/bash
updating cache ../.././config.cache
creating Makefile
creating install-if-change
creating lock-directory
creating unlock-directory
creating config.h
config.h is unchanged
configuring in tools/update
running /bin/sh ../../../../rtems-4.5.0/tools/update/configure
--srcdir=../../../../rtems-4.5.0/tools/update
checking for perl... no
creating Makefile
configuring in tools/cpu
running /bin/sh ../../../../rtems-4.5.0/tools/cpu/configure
--srcdir=../../../../rtems-4.5.0/tools/cpu
creating Makefile
configuring in generic
running /bin/sh ../../../../../rtems-4.5.0/tools/cpu/generic/configure
--target=m68k-rtems --cache-file=../../.././config.cache
--srcdir=../../../../../rtems-4.5.0/tools/cpu/generic
loading cache ../../.././config.cache
updating cache ../../.././config.cache
creating Makefile
creating size_rtems
configuring in m68k-rtems/c
running /bin/sh ../../../../rtems-4.5.0/c/configure  --target=m68k-rtems
--cache-file=./config.cache --srcdir=../../../../rtems-4.5.0/c
creating cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether make sets ${MAKE}... yes
checking for bsps...  dmv152 efi332 efi68k gen68302 gen68340 gen68360
gen68360_040 idp mvme136 mvme147 mvme147s mvme162 mvme162lx mvme167
ods68302 .. done
checking for make/custom/dmv152.cfg... yes
checking for make/custom/efi332.cfg... yes
checking for make/custom/efi68k.cfg... yes
checking for make/custom/gen68302.cfg... yes
checking for make/custom/gen68340.cfg... yes
checking for make/custom/gen68360.cfg... yes
checking for make/custom/gen68360_040.cfg... yes
checking for make/custom/idp.cfg... yes
checking for make/custom/mvme136.cfg... yes
checking for make/custom/mvme147.cfg... yes
checking for make/custom/mvme147s.cfg... yes
checking for make/custom/mvme162.cfg... yes
checking for make/custom/mvme162lx.cfg... yes
checking for make/custom/mvme167.cfg... yes
checking for make/custom/ods68302.cfg... yes
creating Makefile
configuring in make
running /bin/sh ../../../../../rtems-4.5.0/c/make/configure
--target=m68k-rtems --with-target-subdir=m68k-rtems
--cache-file=.././config.cache --srcdir=../../../../../rtems-4.5.0/c/make
loading cache .././config.cache
checking for m68k-rtems-gcc... /opt/rtems/bin/m68k-rtems-gcc
checking whether the C compiler (/opt/rtems/bin/m68k-rtems-gcc  ) works...
Paul Whitfield
Senior Software Engineer
Microsol (Aust) Pty Ltd
Phone: (+61) 08 9473 6646
Fax:   (+61) 08 9473 6699
