network boot
Eric Norum eric.norum at usask.ca
Tue Dec 18 14:33:34 UTC 2001
Davide Del Vento wrote:
> >Chris is the expert on this, but I'll throw in my $0.02 anyhow.
> >I use etherboot to boot my PC targets.  I picked up the bootstrap PROM
> >image from http://www.rom-o-matic.net/.  Here's the script I use to
> >produce a netboot image from the xxxxxx.exe produced by the RTEMS
> >application makefiles.
> Thanks you.
> I reply so later because I had problem with my DHCP server.
> My network administrator now gets it work, but there is still a problem: he
> says that I need to tell RTEMS the DHCP server IP-number, but rom-o-matic
> don't ask me for! When I try to boot with a generated boot image on floppy,
> rtems search for the DHCP server, but it doesn't find and print only dots.
> What's about this?
> Bye,
> ;David
RTEMS, and I presume the boot ROM as well, broadcast the DHCP request
and so need to know neither the IP nor Ethernet address of the DHCP
server.   Try using a network sniffer (for example ethereal if you've
got a linux machine somewhere on the network segment) to see if the
request is making it to the DHCP server and if the server is replying.
Department of Electrical Engineering       Phone: (306) 966-5394
University of Saskatchewan                 FAX:   (306) 966-5407
Saskatoon, Canada.
