network boot
Davide Del Vento davide_rtems at hotmail.com
Tue Dec 18 14:12:50 UTC 2001
>Chris is the expert on this, but I'll throw in my $0.02 anyhow.
>I use etherboot to boot my PC targets.  I picked up the bootstrap PROM
>image from http://www.rom-o-matic.net/.  Here's the script I use to
>produce a netboot image from the xxxxxx.exe produced by the RTEMS
>application makefiles.
Thanks you.
I reply so later because I had problem with my DHCP server.
My network administrator now gets it work, but there is still a problem: he
says that I need to tell RTEMS the DHCP server IP-number, but rom-o-matic
don't ask me for! When I try to boot with a generated boot image on floppy,
rtems search for the DHCP server, but it doesn't find and print only dots.
What's about this?
Bye,
;David
_________________________________________________________________
Chat with friends online, try MSN Messenger: http://messenger.msn.com
