How one can avoid unnecessary code for file I/O?
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Dec 18 14:47:00 UTC 2001
leonp wrote:
> Hello, all .
> Sorry to ask the question, which was, as far as I remember, once asked. But
> I was not able to find it in our mail list, as there is no search capability.
> My project has no system I/O capabilities and tight memory requirements.
> Therefore I am forced to cut out all unnecessary code, such as filesystem,
> console stuff, etc.
> Everything went fine till I tried to use the sprintf function, which
> immediately pulls a lot of file I/O stuff from libc, libc_support and so on.
> Then it looks also for rtems_filesystem_... and all the Co. But all I wanted
> was to produce a string according to my format!!
> I know, that sprintf calls vfprintf and so on...but...
> Does somebody know the simple way to solve this problem and not to write my
> own sprintf?
> Many thanks ahead.
I assume you are also configuring to use the mini-IMFS. That eliminates a lot
of baggage also.
Also if you don't need it, --disable cxx, posix, etc. Each one saves a bit.
>From there, you can do things like avoid using a termios console if you
can get by with that.
> LP
> leonp at plris.com
joel at OARcorp.com On-Line Applications Research
