Multiple Sockets
Eric Norum
eric.norum at usask.ca
Fri Dec 21 14:15:39 UTC 2001
> Bhawani Mittal wrote:
> Hi All,
> In FreeBSD, multiple sockets are taken care by the proc structure.
> But in retem, proc has been implementated as a dummy structure.
> So, in retem can I operate on multiple sockets ( created by multiple
> tasks ) simultaneously ?
> If yes, can anybody tell me how this thing is taken care in RETEM.
Then answer is yes. The only restriction is that a given socket can be
read or written by only one task a time. This is described in the
networking supplement to the RTEMS documentation. I've included the
salient section below. The restriction is pretty minor. I can't think
of any reason why you'd ever want to have two tasks reading from a
particular socket at the same time. Two or more tasks writing to a
socket at the same time is pretty unlikely too since you'd have problems
with data coherency.
3.4: Application Programming Interface
Network Statistics
Tapping Into an Interface
Socket Options
Time Synchronization Using NTP
The RTEMS network package provides almost a complete set of BSD network
services. The network functions work like their BSD counterparts with
the following exceptions:
A given socket can be read or written by only one task at a time.
The select function only works for file descriptors associated
with sockets.
You must call openlog before calling any of the syslog functions.
Some of the network functions are not thread-safe. For example the
following functions return a pointer to a static buffer which remains
valid only until the next call:
gethostbyaddr
gethostbyname
inet_ntoa
(inet_ntop is thread-safe, though).
The RTEMS network package gathers statistics.
Addition of a mechanism to "tap onto" an interface and monitor
every packet received and transmitted.
Addition of SO_SNDWAKEUP and SO_RCVWAKEUP socket options.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
