Runtime network configuration
Andrew Bythell
abythell at nortelnetworks.com
Tue Feb 20 16:18:24 UTC 2001
Hello all.
This question is about network configuration at run-time. I am using
the latest RTEMS snapshot with the gen68360 BSP.
I store network settings in an EEPROM. Currently I declare global
rtems_bsdnet_ifconfig and rtems_bsdnet_configuration structures,
allocate memory for these structures, then copy the data from the EEPROM
into the allocated structures. Then I call
rtems_bsdnet_initialize_network.
Is this the best approach? Do I have to make these variables global?
What I am finding is that BOOTP/DHCP works fine, but using static
settings causes "Destination Host Unreachable" after some time. I feel
the source of the problem must be the way I'm assigning the gateway
address.
Any advice is appreciated.
A.
Andrew Bythell
Nortel Networks System Verification
Ottawa, Ontario Canada esn.39.56930
tel.613.765-6930 fax.613.763-7795
