FTPD crashes in rtems-ss-20010126 with passive mode off
Sergei Organov osv at javad.ru
Mon Feb 5 14:13:25 UTC 2001
That's a known (and already fixed) problem. The patch is available from me by
request.
Sergei.
OUTWATER ~ KEITH J /5G3110 <vac4050 at cae597.rsc.raytheon.com> writes:
> greetings all -
>   I found that when using rtems-ss-20010126, ftpd crashes when I do an 'ls'
> with passive mode on.
>   With passive mode off, things are fine.
>   I'm using a stock Redhat 7.0 system on x86.  I also applied the ftpd patches
> that appeared recently on the list.
>   Keith
> Keith Outwater Principal Engineer Raytheon Missile Systems Tucson, AZ
> (520) 794-2518 vac4050 at cae597.rsc.raytheon.com
