<rtems-users-unsubscribe at oarcorp.com> does not work ?
Jeff Mayes jeff.mayes at oarcorp.com
Fri Feb 9 15:13:28 UTC 2001
Hi
There are some additional instructions for ezmlm that we didn't get placed on
our website.  After seeing these problems numerous times, it is obvious that
we should have added these instructions.
To specify God at heaven.af.mil as your subscription address, send mail
to <rtems-users-subscribe-God=heaven.af.mil at oarcorp.com>.
I'll send a confirmation message to that address; when you receive that
message, simply reply to it to complete your subscription.
This method works for unsubscribe too.  Just replace subscribe,
with unsubscribe.
If you need to unsubscribe an old address, please try this method.  Then
let me know if you are still having problems.
Thanks
Jeff
Joel Sherrill wrote:
> Now that you are back :), I have gotten a couple
> of these now that we handled the one off the list.
> --joel
> -------- Original Message --------
> Subject: Re: <rtems-users-unsubscribe at oarcorp.com> does not work ?
> Date: Thu, 08 Feb 2001 17:54:03 GMT
> From: Jim Clements <Jim.Clements at redstone.army.mil>
> To: joel.sherrill at oarcorp.com
> References: <4.2.0.58.20010208094129.01d74200 at pop3.worldonline.fr>
> <3A829D33.2F947C03 at OARcorp.com>
> I have the same problem.  I believe I started on the list under
> jclement at redstone.army.mil or
> Now my address is Jim.Clements at hwilms.rdec.redstone.army.mil and I can't
> unsubscribe.
> >>>>>>>>>>>>>>>>>> Original Message <<<<<<<<<<<<<<<<<<
> On 2/8/01, 7:20:51 AM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote
> regarding Re: <rtems-users-unsubscribe at oarcorp.com> does not work ?:
> > "stephane at rochebrune.org" wrote:
> > > Hi all,
> > > SORRY to disturb the list. I've followed the advised process to
> > > unsubscribe. (<rtems-users-unsubscribe at oarcorp.com>: Stop receiving
> > > messages). But it does not work.
> > You are now unsubscribed.  I do not know the details on the ezmlm
> > side but if you are unsubscribing a different address than you
> > send from, it is tricky.  It is usually simpler just to get
> > a list admin to do it. :)
> > > My email address is stephane at rochebrune.org (the mailing list recorded
> > > address), redirected from my actual oleron at wordonline.fr (worldonline is
> my
> > > provider). May be the problem is around the redirection. I send messages
> > > from oleron at wordonline with Return-Path: <stephane at rochebrune.org> & From:
> > > "stephane at rochebrune.org" <stephane at rochebrune.org> in the header.
> > > I can't figure HOW to fix this and unsubscribe. Please, help me.
> > > Regards from France.
> > > Stéphane Rivière.
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >    Support Available             (256) 722-9985
