Rebuilding RTEMS
Angelo Fraietta
angelo at hunterlink.net.au
Tue Feb 13 19:13:54 UTC 2001
No, it also happens when I run directly on the Linux machine
Eric Norum wrote:
> Angelo Fraietta wrote:
> > It appears that the linkcmds file is sometimes not being copied into
> > build-rtems/i386-rtems/pc386/lib directory during the make. I can copy it
> > over by hand and complete the build, but I shouldn't really have to.
> > Somewhere during the build process it must copy this file from the
> > appropriate startup directory. If that part fails, maybe the build should
> > stop there??
> > When is the file cpoied over?
> AHA!
> This is exactly what's been happening here, too, for the gen68360 and
> mvme167 targets.
> Are you building on a Linux host with your RTEMS source being mounted
> from another machine via NFS? I've found that the problem never occurs
> when I'm building with the source on a local disk. When I build with
> the source on an NFS mount the linkcmds (and *only* the linkcmds)
> doesn't get copied across and then the build dies when trying to build
> the first example application. It seems to be due to some strange
> interaction between make and NFS. I have not had the time to
> investigate any further.
> Until now I thought I was the only person having this problem. I'm very
> happy to hear that it's not just a delusion on my part.
> Eric Norum eric.norum at usask.ca
> Department of Electrical Engineering Phone: (306) 966-5394
> University of Saskatchewan FAX: (306) 966-5407
> Saskatoon, Canada.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://users.hunterlink.net.au/~maaaf/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
