Error on netdemo 4.5.0 example
Nick.SIMON at syntegra.bt.co.uk Nick.SIMON at syntegra.bt.co.uk
Tue Feb 20 11:31:22 UTC 2001
It could be you haven't got enough file handles.  Look in init.c for
definition of CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS.
-- Nick Simon
> -----Original Message-----
> From: kanmo at cisl.snu.ac.kr [mailto:kanmo at cisl.snu.ac.kr]
> Sent: 20 February 2001 10:58
> To: rtems-users
> Subject: Error on netdemo 4.5.0 example
> we build rtems system on the system of i386 processor and pc386 bsp.
> And we use ISA 3c509 network card.
> However, we met a problem on the execution of netdemo program.
> we think that the configuration is right.
> the execution screen is as follows. it shows error message.
> 3C509: attach() called
> 3C509: isa_probe() looking for a card
> 1 3C5x9 board(s) on ISA found at 0x300
> 3C509: I/O=0x300, IRQ=10, CONNECTOR=UTP, ADDRESS=0xa0 2407 1015
> 3c509: attach() is complete
> Can't create initial socket: Too many open files in system
> No routes!
> Create Socket
> RTEMS: Can't create socket: Too many open files in system
> RTEMS: fatal error, exiting
> EXECUTIVE SHUTDOWN! Any key to reboot...
> plx, help~~
> good luck for all of you.
Check us out at http://www.syntegra.com
