ping reply stops after some time
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 23 14:11:51 UTC 2001
peter.o.mueller at gmx.de wrote:
> Hi,
> I have just finished to get our new 68332 hardware up and running (at
> least partly). We use rtems (one of the latest snapshots) together with the
> cs8900 driver from Chris Johns. Everythings looks fine so far.
> After a fresh download (via bdm) my target replies to ping several
> times, but after some time (e.g. 6 pings) there was no reply from my
> target anymore. The target is still alive and I can break and debug it
> using bdm. Looking on the network statistics (see below) shows that sill
> ping requests (and lots of other stuff, becaus there is some network
> traffic) are received, but the figures on the transmitter stand still.
> I have no idea where to start debugging. My feeling is that the
> transmitter task has stopped working, but I do not really know.
> Can someone give me hints how to start debugging?
Some random things to look at ...
+ too many interrupts masked on the chip
+ not returning resources (TX?)
+ "wrapping" some HW list/queue (i.e. 1st n work but n+1
trips a wrap boundary
+ Is the RX daemon waking up ?
More than likely given > 4K interrupts, you have run out of something.
Check frees and reclamation code. :)
> Thank you very much,
> Peter
> The following shows the statistics screen after there is no reply to
> pings:
> ************ UDP Statistics ************
> total input packets 6
> of above, arrived as broadcast 6
> ************ TCP Statistics ************
> Destination Gateway/Mask/Hw Flags Refs Use Expire
> Interface
> default 138.222.94.1 UGS 0 0 0 cs0
> 138.222.94.0 255.255.255.0 U 0 0 1 cs0
> 138.222.94.1 UHL 1 0 1 cs0
> 138.222.94.27 00:10:4B:B2:04:78 UHL 0 69 1261 cs0
> ************ MBUF STATISTICS ************
> mbufs: 512 clusters: 64 free: 0
> drops: 0 waits: 0 drains: 0
> free:425 data:87 header:0 socket:0
> pcb:0 rtable:0 htable:0 atable:0
> soname:0 soopts:0 ftable:0 rights:0
> ifaddr:0 control:0 oobdata:0
> ************ INTERFACE STATISTICS ************
> ***** cs0 *****
> Address:138.222.94.66 Broadcast Address:138.222.94.255
> Flags: Up Broadcast Running Active Simplex
> Send queue limit:50 length:22 Dropped:0
> Network Driver Stats for CS8900 :
> rx ready len - 42 rx loaded len - 0
> rx packets - 3802 tx packets - 52
> rx bytes - 447003 tx bytes - 4946
> rx interrupts - 4556 tx interrupts - 51
> rx dropped - 377 rx no mbuf - 0
> rx no custers - 1259 rx oversize errors - 0
> rx crc errors - 0 rx runt errors - 0
> rx missed errors - 475 tx ok - 51
> tx collisions - 0 tx bid errors - 0
> tx wait for rdy4tx - 0 tx rdy4tx - 0
> tx underrun errors - 0 tx dropped - 0
> tx resends - 0 int swint req - 11
> int swint res - 11 int lockup - 0
> interrupts - 2586
> ************ IP Statistics ************
> total packets received 2340
> packets rcvd for unreachable dest 2265
> datagrams delivered to upper level 75
> total ip packets generated here 69
> ************ ICMP Statistics ************
> Type 0 sent 69
> number of responses 69
> Type 8 received 69
> Sent through GMX FreeMail - http://www.gmx.net
joel at OARcorp.com On-Line Applications Research
