Linking against Rom Image
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 26 19:28:24 UTC 2001
Peter Müller wrote:
> Hi,
> some time ago I already trieded to figure out how it is possible to link an
> application against code that is already available in ROM. But it found no
> good solution since then.
> The reason why I want to do this is that my application (+rtems) is several
> hundred kilobytes large and developing cycles (download, debug ...) takes to
> long.
> Because the rtems code itself is always the same I would like to have it on
> ROM (e.g. starting from 0). The application resides in RAM and is linked
> against rtems located in ROM. So only the application has to be downloaded
> for debugging.
> How can I do this? Is there a way to link the app against rtems, but not
> include rtems in the final exe file? Any docu about that?
Chris Johns has done something like this with My Right Boot.
GNU ld has an option to link against a previously linked image. This
is what you want. Here is the excerpt from the ld docs:
`-R FILENAME'
`--just-symbols=FILENAME'
Read symbol names and their addresses from FILENAME, but do not
relocate it or include it in the output. This allows your output
file to refer symbolically to absolute locations of memory defined
in other programs. You may use this option more than once.
For compatibility with other ELF linkers, if the `-R' option is
followed by a directory name, rather than a file name, it is
treated as the `-rpath' option.
> Thank you very much,
> Peter
joel at OARcorp.com On-Line Applications Research
