[RTEMS]Kernel info?
Jeffrey
jeffrey at antek.com.tw
Tue Jan 2 03:25:34 UTC 2001
Hi All:
I studied the RTEMS c user's guide, found that RTEMS does not have any
kernel related debug info api calls(e.g. task's current stack size,
minimum stack size, message queue's current remaining queue
length/minimum queue length...). All the other famous RTOS(pSOS, Nucleus,
VxWorks) have lots of these kernel related debug info api. Are you
planning to provide these functions or have provided but not documented ?
Please kindly tell me. Thanks in advance. ( The VxWorks even provide
call back function for each context switch, this is helpful if we want
to know which task is consuming most of the cpu resource.)
Sincerely,
Jeffrey Wu
