Time and NTP on RTEMS
Jake Janovetz
janovetz at uiuc.edu
Sat Jan 27 22:55:16 UTC 2001
Hello...
I've recently needed to integrate time into my RTEMS applications
and have a couple questions. I see that the NTP is supported, but only
in single-query mode (not a daemon). This should be adequate for what
I want. I have called time(), then localtime(), then strftime() to
get a printout of the current time, but I see that the time is off
by several hours, so I assume the timezone has not been properly
set. How is this supposed to be done in RTEMS?
Daemon mode of NTP is relatively complicated if I understand it
correctly (having to continually make small adjustments to slide the
device time to the proper time). Is this something currently under
development (for RTEMS)?
Thanks!
Jake
