RTEMS snapshot ss-20010126 available
Sergei Organov
osv at javad.ru
Mon Jan 29 14:18:02 UTC 2001
Jake Janovetz <janovetz at uiuc.edu> writes:
> 3. Hooks are broken (the filename comparison doesn't appear to
> work anymore -- I put to a hook and it just creates a file with
> that name. [this one particularly sucked because I could not
> download an old code image... I had to dig out the debug cable
> and do the gdb song and dance]
> -- This one occurs because you take the filename and the CWD and
> build a new filename. This new filename may/may not match the
> hook. Originally, I planned that hooks would not depend on the
> current working directory. I don't know what you have in mind
> for the revised setup.
If you need the hook to don't depend on current working directory, call it so
that its name begins with `/'. Or is it a problem? Does it work for you?
BR,
Sergei.
