ERC32 BSP & snapshop 20010109
Antonio da Silva Fariña adasilva at diatel.upm.es
Wed Jan 31 09:25:40 UTC 2001
Hi,
There is any known problem with this BSP and snapshot.
The hello.exe sample seems not to work fine.
[root at castor samples]# sparc-rtems-gdb  hello.exe
GNU gdb 5.0
Copyright 2000 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for
details.
This GDB was configured as "--host=i686-pc-linux-gnu
--target=sparc-rtems"...
(gdb) set remotebaud 19200
(gdb) tar rem /dev/ttyS1
Remote debugging using /dev/ttyS1
0x2000000 in trap_table ()
(gdb) lo
Loading section .text, size 0x18110 lma 0x2000000
Loading section .data, size 0x9e0 lma 0x2018110
Start address 0x2000000 , load size 101104
Transfer rate: 6522 bits/sec, 277 bytes/write.
(gdb) run
The program being debugged has been started already.
And nothing happens in console
Thanks in advance
_______________________________________________________________________
 DIATEL-UPM                URL:    http://www.diatel.upm.es/~adasilva/
 EUIT Telecomunicación     mailto: adasilva at diatel.upm.es
 Ctra. Valencia, Km. 7  Tel: +34 91 3367812   Fax: +34 91 3367817
 28031 Madrid, SPAIN
_________________________________________________________________________
