ERC32 BSP & snapshop 20010109
Radzislaw Galler rgaller at ET.PUT.Poznan.PL
Wed Jan 31 11:51:49 UTC 2001
Antonio da Silva Farińa wrote:
> Hi,
> There is any known problem with this BSP and snapshot.
> The hello.exe sample seems not to work fine.
> [root at castor samples]# sparc-rtems-gdb  hello.exe
> GNU gdb 5.0
> Copyright 2000 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you
> are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB.  Type "show warranty" for
> details.
> This GDB was configured as "--host=i686-pc-linux-gnu
> --target=sparc-rtems"...
> (gdb) set remotebaud 19200
> (gdb) tar rem /dev/ttyS1
> Remote debugging using /dev/ttyS1
> 0x2000000 in trap_table ()
> (gdb) lo
> Loading section .text, size 0x18110 lma 0x2000000
> Loading section .data, size 0x9e0 lma 0x2018110
> Start address 0x2000000 , load size 101104
> Transfer rate: 6522 bits/sec, 277 bytes/write.
> (gdb) run
> The program being debugged has been started already.
You should say rather 'continue' than 'run' - then it should work.
Regards
Radek
