RTEMS monitor question
Gerke Kok gerke.kok at tpa-nl.com
Tue Jan 30 12:53:42 UTC 2001
In bash and other shells it is standard to pre-fix the command line with a
'!' exclamation mark. We could use that... You could even use the !xxx to
search the history of commands and start anything that starts with 'xxx'.
wkr,
Gerke
-----Oorspronkelijk bericht-----
Van: Chris Johns [mailto:cjohns at cybertec.com.au]
Verzonden: Tuesday, January 30, 2001 13:36
Aan: 'Rtems-Users (E-mail)
Onderwerp: Re: RTEMS monitor question
"Fernando RUIZ CASAS (E-mail)" wrote:
> And repeat last command is very awfull.
> After add a flash erase command all times that I press enter a new flash
> erase is called.
> I propose add a little 'r' (repeat) command... Two keys for the same
> propose.
Maybe there should be an option to configure it. I find it useful in gdb
so copied it.
 Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
