ERC32 BSP & snapshop 20010109
jiri at gaisler.com jiri at gaisler.com
Wed Jan 31 13:45:30 UTC 2001
It's not obvious from your mail which monitor you are using on your
target hardware. If you are using rdbmon as proided in ERC32CCS, you
need to follow the instructions, i.e. use the supplied gdb-4.17 and
connect with 'target erc32 /dev/ttyS00'.  I would advise to use the
new LECCS compiler system (see www.gaisler.com) which contains a
new monitor that uses the 'extended-remote' protocol and can be
used with an unmodified gdb-5.0.
Also note that any output from the target applications will not be
visible in the gdb console but sent on MEC UART A, so you need to
connect a terminal window to this port.
Jiri.
Gaisler Research, Plantageg. 5, 41305 Goteborg, Sweden, +46-73-9927100
email: jiri at gaisler.com, home page: http://www.gaisler.com
