ERC32 BSP & snapshop 20010109
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jan 31 12:26:46 UTC 2001
Antonio da Silva Fariña wrote:
> Hi,
> There is any known problem with this BSP and snapshot.
> The hello.exe sample seems not to work fine.
Since you are using the gdb remote debug protocol to get to
what I can only assume is a real piece of hardware, I have to
ask does it work if you do this sequence:
tar sim
load
run
If it runs this way, then there is some difference between
the "board" the simulator simulates and your real hardware.
More than likely, it would be a memory layout type thing.
There was a breakage in the sparc port between Decembr 19 and
when the fix was checked on January 3. So any snapshot between
those dates is broken.
> [root at castor samples]# sparc-rtems-gdb hello.exe
> GNU gdb 5.0
> Copyright 2000 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you
> are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show warranty" for
> details.
> This GDB was configured as "--host=i686-pc-linux-gnu
> --target=sparc-rtems"...
> (gdb) set remotebaud 19200
> (gdb) tar rem /dev/ttyS1
> Remote debugging using /dev/ttyS1
> 0x2000000 in trap_table ()
> (gdb) lo
> Loading section .text, size 0x18110 lma 0x2000000
> Loading section .data, size 0x9e0 lma 0x2018110
> Start address 0x2000000 , load size 101104
> Transfer rate: 6522 bits/sec, 277 bytes/write.
> (gdb) run
> The program being debugged has been started already.
> And nothing happens in console
> Thanks in advance
> _______________________________________________________________________
> DIATEL-UPM URL: http://www.diatel.upm.es/~adasilva/
> EUIT Telecomunicación mailto: adasilva at diatel.upm.es
> Ctra. Valencia, Km. 7 Tel: +34 91 3367812 Fax: +34 91 3367817
> 28031 Madrid, SPAIN
> _________________________________________________________________________
joel at OARcorp.com On-Line Applications Research
