Comm ports on Pc386
Fernando RUIZ CASAS (E-mail) fernando.ruiz at ctv.es
Mon Jul 2 07:41:06 UTC 2001
Hi
If you want to use shell_init without tpc/ip enabled I can send to you
the patch already submitted to Joel.(05/26/01)
I have not made none modification in the pc386 BSP code to enable
the ports. Only this code has been used.
In shell_init only a make raw mode TERMIOS is done
(How the linux man page says)
None error is showed in the compilation of pc386(pc686) bsp.
Browse in the sources and ask directely to Eric, Rosimildo & more about the
use of this. (The authors of little patchs...)
I have use this ports like a linux device using only TERMIOS programming.
And this works successfully.
Your code seems correct. I Can try it.
Fernando RUIZ CASAS
home:correo at fernando-ruiz.com
work:fernando.ruiz at ctv.es
> -----Mensaje original-----
> De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> Enviado el: lunes, 02 de julio de 2001 3:38
> Para: correo at fernando-ruiz.com
> CC: Rtems-Users (E-mail)
> Asunto: Re: Comm ports on Pc386
> I am using the previous snapshot as  do not have networking
> enabled. I am
> trying to open the commport and write some chars (for now).
> If I just try to
> open the port without the code you provided, the file does
> not open. I assume
> it is because the port has to be configured with the code you
> provided.
> However, trying to compile this below, I get a heap of parse errors in
> ttr_drv.h.
> Is this because of the snapshot or am I doing something wrong here?
> #include <tty_drv.h>
> #include <console.h>
> #include <clockdrv.h>
> #include <timerdrv.h>
> rtems_driver_address_table Device_drivers[] = {
>         CONSOLE_DRIVER_TABLE_ENTRY,
>         TTY1_DRIVER_TABLE_ENTRY,
>         TTY2_DRIVER_TABLE_ENTRY,
>         CLOCK_DRIVER_TABLE_ENTRY,
>         {NULL,NULL,NULL,NULL,NULL,NULL},
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MAXIMUM_TASKS             1
> #include <confdefs.h>
> rtems_id   Task_id;
> rtems_name Task_name;
> const char* tty_ports [] =
>  "/dev/ttyS1",
>  "/dev/ttyS2"
> rtems_task Test_task(
>   rtems_task_argument unused
>  FILE* fp = fopen (tty_ports [0], "r+");
>  if (!fp)
>    printf ("Unable to open %s", tty_ports [0]);
>  else
>    while (1)
>      if (!fputc('t', fp))
>        printf ("unable to write to port");
> Init()
>  Task_name = rtems_build_name( 'T', 'A', '1', ' ' );
>   rtems_status_code status;
>   status = rtems_task_create(
>     Task_name, 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
>     RTEMS_DEFAULT_ATTRIBUTES, &Task_id
>   status = rtems_task_start( &Task_id, Test_task, 1 );
> > > Enviado el: jueves, 28 de junio de 2001 3:52
> > > Para: rtems-users
> > > Asunto: Comm ports on Pc386
> > > Does anyone have an example of using the comm ports on a
> PC386 build?
> > Adding this like rtems device configuration you have
> > THREE termios ports in your PC.
> > /dev/console
> > /dev/ttyS1
> > /dev/ttyS2
> > How to manage this ports with TERMIOS?
> > See the /rtems/c/src/tests/libtests/termios directory.
> > A complete program to drive a termios device.
> > (My first source to understand it. Thanks Eric Norum)
> > Enjoy it.
> > Are you using the last snapshot (20010525)?
> > With this you can open remote consoles in every port termios.
> > /* TASK NAME,STACK SIZE, TASK PRIO, DEV_NAME, BAUDS & LINE
> SETT.,FOREVER*/
> > #include <shell.h>
> > Init() {
> > shell_init("sh1",16384,100,"/dev/ttyS1"  ,B38400|CS8,TRUE);
> > shell_init("sh2",16384,100,"/dev/ttyS2"  ,B38400|CS8,TRUE);
> > shell_init("shc",16384,100,"/dev/console",B38400|CS8,TRUE);
> > Three users accessing at same time at the PC but with RTEMS rtos.
> > A new task for evevy user.
> > Fernando RUIZ CASAS
> > home: correo at fernando-ruiz.com
> > work: fernando.ruiz at ctv.es
> > > Angelo Fraietta
> > > PO Box 859
> > > Hamilton NSW 2303
> > > Home Page
> > > http://users.hunterlink.net.au/~maaaf/
> > > There are those who seek knowledge for the sake of
> knowledge - that is
> > > CURIOSITY
> > > There are those who seek knowledge to be known by others - that is
> > > VANITY
> > > There are those who seek knowledge in order to serve -
> that is LOVE
> > >     Bernard of Clairvaux (1090 - 1153)
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> There are those who seek knowledge for the sake of knowledge - that is
> CURIOSITY
> that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
