Patch To avoid tcp/ip enabled in last snapshot (25052001)
Fernando RUIZ CASAS (E-mail)
fernando.ruiz at ctv.es
Mon Jul 2 12:37:47 UTC 2001
Hi rtems-users.
In order to build the last snapshot with tcp/ip disabled here a patch
moving the telnetd and pty to libnetworking directory.
This patch is already submitted to Joel.
But while the new snapshot arrives,a solution is here.
Sorry for the inconvenience.
Fernando RUIZ CASAS
home:correo at fernando-ruiz.com
work:fernando.ruiz at ctv.es
-----Mensaje original-----
De: Correo Fernando-ruiz (E-mail) [mailto:correo at fernando-ruiz.com]
Enviado el: lunes, 28 de mayo de 2001 8:49
Para: joel.sherrill at OARcorp.com; Fernando RUIZ CASAS (E-mail) (E-mail)
Asunto: RE: RTEMS SS-20010525 Available
In order to set up the last rtems snapshot this patch resolve the little
bugs
in the telnetd environment already discussed.
The psxchroot01 has been fixed.
Regards
Fernando RUIZ CASAS
home: correo at fernando-ruiz.com
work: fernando.ruiz at ctv.es
> De: joel [mailto:joel]En nombre de Joel Sherrill
> Enviado el: viernes, 25 de mayo de 2001 21:26
> Para: rtems-users at OARcorp.com; rtems-snapshots at OARcorp.com
> Asunto: RTEMS SS-20010525 Available
> In ftp.oarcorp.com /pub/rtems/snapshots/rtems/current.
> This snapshot includes improvements to the MIPS exception
> and interrupt processing, the Robominds MRM BSP, more
> configuration changes in the move to a BSP Kit, initial
> support for telnetd, improvements to the motorola BSPs,
> and some miscellaneous bug fixes.
> I have modified the script to generate bzip since they are
> about 40% smaller than gzip'ed images. The script did not
> correctly generate the diff so I did it by hand. I will
> get the script fixed before the next snapshot. :)
> Enjoy.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010702/e31e118b/attachment.obj>
