Patch To avoid tcp/ip enabled in last snapshot (25052001)
Fernando RUIZ CASAS (E-mail) fernando.ruiz at ctv.es
Tue Jul 3 07:04:07 UTC 2001
Hi Angelo.
 Yesterday. I have could rebuild in cygwin (In Linux no problem) all the
 tool chain including the last snapshot and build a new BSP pc686
 without problems (With the patch applied).
 What kind of problems have you?
 Rebuilding the BSP with
  make all install 2>errorfile
 you can capture the errors.
Fernando RUIZ CASAS
home:correo at fernando-ruiz.com
work:fernando.ruiz at ctv.es
> -----Mensaje original-----
> De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> Enviado el: martes, 03 de julio de 2001 7:55
> Para: fernando.ruiz at ctv.es
> Asunto: Re: Patch To avoid tcp/ip enabled in last snapshot (25052001)
> I applied the patch, however, it appears that only the pc386
> is successfully being built. I get
> configure errors when I try to build pc386dx and pc686.
> "Fernando RUIZ CASAS (E-mail)" wrote:
> > Hi rtems-users.
> > In order to build the last snapshot with tcp/ip disabled
> here a patch
> > moving the telnetd and pty to libnetworking directory.
> > This patch is already submitted to Joel.
> > But while the new snapshot arrives,a solution is here.
> > Sorry for the inconvenience.
> > Fernando RUIZ CASAS
> > De: Correo Fernando-ruiz (E-mail) [mailto:correo at fernando-ruiz.com]
> > Enviado el: lunes, 28 de mayo de 2001 8:49
> > Para: joel.sherrill at OARcorp.com; Fernando RUIZ CASAS
> (E-mail) (E-mail)
> > Asunto: RE: RTEMS SS-20010525 Available
> > In order to set up the last rtems snapshot this patch
> resolve the little
> > bugs
> > in the telnetd environment already discussed.
> > The psxchroot01 has been fixed.
> > Regards
> > Fernando RUIZ CASAS
> > home: correo at fernando-ruiz.com
> > work: fernando.ruiz at ctv.es
> > > De: joel [mailto:joel]En nombre de Joel Sherrill
> > > Enviado el: viernes, 25 de mayo de 2001 21:26
> > > Para: rtems-users at OARcorp.com; rtems-snapshots at OARcorp.com
> > > Asunto: RTEMS SS-20010525 Available
> > > In ftp.oarcorp.com /pub/rtems/snapshots/rtems/current.
> > > This snapshot includes improvements to the MIPS exception
> > > and interrupt processing, the Robominds MRM BSP, more
> > > configuration changes in the move to a BSP Kit, initial
> > > support for telnetd, improvements to the motorola BSPs,
> > > and some miscellaneous bug fixes.
> > > I have modified the script to generate bzip since they are
> > > about 40% smaller than gzip'ed images.  The script did not
> > > correctly generate the diff so I did it by hand.  I will
> > > get the script fixed before the next snapshot. :)
> > > Enjoy.
> > > Joel Sherrill, Ph.D.             Director of Research &
> Development
> > > joel at OARcorp.com                 On-Line Applications Research
> > > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > >    Support Available             (256) 722-9985
> >                                        Name:
> rtems-ss-20010125.shell.diff.bz2
> >    rtems-ss-20010125.shell.diff.bz2    Type: Macintosh
> StuffIt Archive (application/x-stuffit)
> >                                    Encoding: base64
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://users.hunterlink.net.au/~maaaf/
> There are those who seek knowledge for the sake of knowledge
> - that is CURIOSITY
> There are those who seek knowledge to be known by others -
> that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
