Cygwin hosted cross compilers
gregory.menke at gsfc.nasa.gov
Tue Jul 3 19:56:43 UTC 2001
Below is my original posting, I've learned a little more about it. I
did a comparison of nm and objdump outputs from the Linux and Doze
generated objects. Many of the objects were identical, but many
weren't. The most obvious difference was a slightly different
strategy in the assembly generation.
Generally, the Windows compiler seemed to do some 32 bit ops as 2 16
bit ops; set a register to 0 is done in one store word by the Linux
compiler, yet by 2 16 bit ops by the Windows version. Quite strange,
maybe something to do with the optimizer. The compiler flags are
exactly the same for both the Windows & Linux builds.
Does this ring any bells yet?
Gregm
> > We're sucessfully using the Linux hosted MIPS compilers for our R3000
> > target, and are trying to bring up the Cygwin hosted ones so those
> > cursed with Windows can compile the app.
> > The compilation is working OK, except a number of source files don't
> > end up with the identical .o output file. About half end up OK. For
> > those that aren't identical, comparing nm and objdump's output for the
> > .o files generated for given .c file by the Cygwin and Linux hosted
> > compilers shows the same symbols and the same assembly, but the
> > addresses are shifted between a few bytes and quite a number. Its
> > almost as if sizeof() is returning something different- or code/data
> > alignment is being performed differently.
> > This looks non-trivial because the same code compiled under Linux
> > runs, but under Cygwin, fails with unaligned access exceptions in
> > known good code. RTEMS itself does start up, however.
> > I'm compiling under Cygwin using the ntvdm registry hack, and the
> > makefile is identical for builds on either host.
> > I'm about ready do start more carefully comparing the output from a
> > test .c file and try to narrow things down. Has anyone seen similar
> > behavior under Cygwin?
