i386-rtems works now with plex86
Thomas Bocek
draft at icu.unizh.ch
Wed Jul 4 18:06:09 UTC 2001
i386-rtems "hello world" works with plex86!!
On Tuesday 03 July 2001 19:47, Joel Sherrill wrote:
> Thomas Bocek wrote:
> > It works now and all my questions I posted are solved. Has anyone tried
> > rtems-i386 on plex86 (x86 emulator)? I did but it does not work. It says:
> > error code pushed by processor itself (if not 0) = 0
> > ** FAULTY THREAD WILL BE DELETED **
> > Exception caught at PC 1412A by thread 7471202
> Was that the entire message printed? Usually there is some exception
> type information ahead of that.
there was and endless loop with this message.
> > what does this mean?
> It means that an unexpected exception occurred. This is generally
> an error. Some hints are that it is an unexpected device interrupt
> or an exception such as illegal instruction, non-existent memory, etc.
> Since you are on plex86, I would guess that it would likely not
> follow the typical patterns exactly. What code is at 1412A according
> to the symbol table? Is there a specific instruction causing the
> fault?
The Exception was performed by finit (floating point init). It seems the
plex86 does not support fpu, or the initilisation has a bug. So I disabled
fpu. (where is the correct place to deacitvate fpu. I removed the fpu init
code)
> It could be a plex86 configuration problem. According to the plex86
> archives, I reported some success back in December. :)
I didnt use grub: I wrote a bootloader, and merged the bootloader,
start16.bin and the kernel image (.bin) into a file. And then I booted this
file as a floppy image with plex86. I had to make some modification at the
rtems source code.
I collect the modifications and I will send it to you.
> http://www.mail-archive.com/plex86@fastxs.net/msg01379.html
> The RTEMS Guest file was added back in October according to this:
> http://www.mail-archive.com/plex86@fastxs.net/msg00535.html
> I do not think I ever had any luck with Microwindows but mostly because
> I did not have time to pursue prior to the holidays.
> I would really like to get plex86 working as it could provide a nice
> test environment. :)
Regards
Thomas
