Problems with arm-rtems-gcc
wangyf(sina) wangyf_tshua at sina.com
Thu Jul 12 09:26:37 UTC 2001
But where can I get gcc 2.95.3 for rtems? Can I use arm-linux-gcc to compile RTEMS?
Best regards,
yunfei
----- Original Message -----
To: "wangyf(sina)" <wangyf_tshua at sina.com>
Cc: <rtems-users at oarcorp.com>
Sent: Thursday, July 12, 2001 4:20 AM
Subject: Re: Problems with arm-rtems-gcc
> On Wed, Jul 11, 2001 at 09:16:06PM +0800, wangyf(sina) wrote:
> > Hi, Dear all,
> > I have download arm-rtems-gcc-gcc2.95.2newlib1.9.0-2.i386.rpm from ftp.oarcorp.com and install it. I can build RTEMS with it, but it cannot accept "-fpack-struct" option. If I type " arm-rtems-gcc ... -fpack-struct ... ", there is no error happening, but the structures in my program will not be packed.
> > Has anyone met such a problem before? Please comment.
> > Thanks!
> I had problems using arm-linux-gcc 2.95.2 in another project. At the
> very least, it generates incorrect code when it optimises 32-bit
> constant loading/generation.
> This is where it replaced a 32 bit load of a constant from memory with
> two instructions to build it using immediates. My assumption was that
> the machine description for some ARM instructions was incorrect.
> arm gcc 2.95.3 is working fine for me.
>  -Marc
> > Best regards,
> > Yunfei Wang
> Marc Salem
> m.salem at unsw.edu.au
> 0416 033 180
> UNSW Solar Racing Team          School Of Computer Science & Engineering
> http://www.sunswift.com/        http://www.cse.unsw.edu.au/
