i386/pc386 COM2 Serial Port Problem
Mike Siers mikes at poliac.com
Mon Jul 23 19:47:58 UTC 2001
Hi,
I have program that works perfectly when I use the COM1 serial port.
If I switch the application to use COM2 instead of COM1, it does not
work.  It does not look like any data gets transmitted out over the port.
I have both the tty drivers in my device driver table and I see the device
initialized message for both COM ports.  I also have the number of
file descriptors set to 8.
Has anyone seen this problem?  My application requires that I use both
COM ports.  This test application is only using one port at a time but it
does not work with COM2.  I am using the latest snapshot 2001/07/12.
Thanks
Mike Siers
URL: <http://lists.rtems.org/pipermail/users/attachments/20010723/64af5075/attachment.html>
