PPPD Update
Mike Siers
mikes at poliac.com
Mon Jul 23 20:00:20 UTC 2001
Hi,
The attached files provide a fresh port of pppd 2.3.11 for RTEMS.
I have done all my testing with the i386/pc586 BSP.
Please try it out. I would like to get these changes merged into
the next snapshot.
Installation:
1) Apply patch file to snapshot 2001/07/12
(if using i386, you also need to update tty_drv.c to use task driven I/O)
2) Rename the c/src/libnetworking/pppd directory
3) Untar the new pppd code into the c/src/libnetworking directory
4) Rebuild RTEMS
5) Check out the new example program in c/src/libnetworking/pppd/example
Thanks
Mike Siers
URL: <http://lists.rtems.org/pipermail/users/attachments/20010723/21f4c059/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010723/21f4c059/attachment.obj>
Type: application/x-compressed
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010723/21f4c059/attachment.bin>
